1 - 5 of 5 Posts
Does anyone know the specs on the oem needle on a 90 model mc22 set of carbs? Backstory I have a 89 mc19 that I bought sight unseen and imported to the US and it has had a set of mc22l carbs installed at some point. Problem is I've been dealing with a rich condition at idle and small throttle openings. After having the carbs off a dozen times I believe I'm getting some fuel bleeding from the needle and it is a different part number than what is called for in the manual j93b is what is called for and j4ga is what is installed.
Discussion Starter · #4 ·
Any know the needle tip diameter? The vp20a and vp20b call for different part number. I'm wondering if the vp20b needles are thinner/richer to go along with the richer mains on the b's . Also am i correct in saying that these are vp20b carbs?
Motor vehicle Automotive tire Gas Machine Nut
1 - 5 of 5 Posts
