21 - 22 of 22 Posts
Discussion Starter · #21 ·
I'm not sure what shorting the cables on the relay means or does, but it sounds like you have found your problem :)
on the starter relay i bypassed the Relay itself and gave power to the starter motor making it turn. Basically put the Positive end of the cable onto the cable leading to the starter motor.
I didn't know that's what you called "shorting" .. but all good.
Repost time - Sounds like you've found your problem though if that works, the relay is shagged.
21 - 22 of 22 Posts
