esvir said:
good day mates,need help on my carb problem...installed my carb twice on
my bike after cleaning the carb coz it wont stop leaking fuel as i start the
bike....i think its because of my float switch..what do you call those things
that stops the fuel? i think theyre worn out....what can be done...thanks
Clean and polish the float valve seats with a cotton stick with autosol attached to a drill. Don't use to much pressure on the drill other wise the stick will bend.
Then check the float valves and the little pointy rubber bit and make sure that they're clean and don't have indentations on them and if they do, replace them. Not sure how they cost at Honda but I got some spare ones.
A little test I used to check whether they were working was to flip the carbs upside down, assemble the floats, valves and have them in the carbs but have the bowls off put some fuel down the fuel hose and apply light air pressure on the hose to replicate the weight of the fuel in the tank. If fuel comes out from the seats and where the valves are then you know that it is leaking there.
