1 - 2 of 2 Posts
G'day I had my carbs synced a few months ago idles more consistent might be a dumb question but would turning the idle up or down effect the sync at all because I think when syncing carbs the idle adjuster is used in the process??
idle adjustment does not effect sync. it moves all the butterflies when adjusting it. the idle adjuster is only used to turn up/down the idle when syncing so that it's at the proper place. If it does effect sync, theres something wrong with the carb setup.
1 - 2 of 2 Posts
