1 - 4 of 4 Posts
Hello everyone, i am thinking about buying a used MC22. But it has an engine problem, the owner says its Crankshaft is broken(or something). So any opinions on what should i do? Is it expensive to repair? What other crankshafts can i find(CBR 400RR/600RR etc.)?
I would not buy a bike with engine damage when the seller is that vague and your mechanical knowledge is also limited.
Unless you want it for parts.
you can find all sort of crank shafts, but they wont fit. stuffed crank can result in all sorts of problems - best to just put another engine in it - in saying that i agree with Lane as it appears you have very limited knowledge on bike engines. unless you are mechanically minded, i would not buy or atempt to fix.
Discussion Starter #4
My father is a good mechanic, but i suppose it's not worth the trouble. I hope i will find a nice MC22 since i am from Serbia and there aren't any on sale now. Thanks a lot for your reply i really appreciate it. (both)
1 - 4 of 4 Posts
