Ok so i was currious if i could get away saving a few bucks buying one of those chinese head gaskets on ebay... i was thinking "it's just a damn gasket, how could they go wrong about it".
Boy was i surprised how stupid/wrong/ignorant/careless these chinese could be. The Gasket shape and thickness is spot on. Everything else is wrong.
1- stamping (embossing) thickness is pretty irregular and some spots on the gasket is almost flat. This means tha there will not be enough deformation/pressure from the gasket to seal properly on those areas
2- No coatings on the gasket. (Oem has a very thin coat of sealer that looks like black paint) Meaning that the gasket will not seal fluids at all because aluminum on steel will not create a fluid proof seal. This even leads to the gasket having some rust on it which again, will prevent a good seal.
3- the embossing pattern is incorrect. The embossed patern goes on the wrong side of the head bolts, which means that you have high chances of getting coolant in the crankcases trough the head bolts. The oil return galleries are not even embossed so they will most likely seep oil on the exhaust header. This is most likely to create an "end of the world" type situation where smoke and burned oil smell comes out of the bike or worst, bike catches on fire. And besides, there is about only half of the OEM gaskets embossings on the chinese crap so you can be assured it will NEVER EVER seal properly.
So i wanted to share my engineering analysis of these cheap gaskets to prevent people from waisting their money on those, having leaking problems or worst, destroy a good bottom end because of coolant flowing into the crankcase.
