141 - 145 of 145 Posts
Thanks Aduro, i will do that then. Although i was afraid that would be the answer! Iv only stripped carbs from single cylinder bikes so this will be a learning experience. All good fun though im sure. What should the standard jet size and pilot screw settings be? It was the mechanic at the MOT place that advised me to get the hi flo filter! I will just get a standard filter then as my current one is pretty dirty.
drain screw for the float bowl is just a screw that...lets you drain the floats. (for when you're cleaning them/for some reason need to drain the float).
You don't have to set it. As long as it's not leaking then it's fine.
