1 - 2 of 2 Posts
Hi i noticed the smaller lock nut on the engine adjuster came off got it back on and spent ages trying to adjust it propely in the 1st pic if the cable is like that it works but if i put the cable in the perch in the 2nd photo theres no tension on the lever do i need a new clutch cable
you need to use adjuster properly.
1. unscrew inner barrel outwards so it's 7mm further away from lever & engine
2. screw large ring locknut on outside, towards lever and engine so it locks inner adjuster in position.
You want to unscrew adjuster so even more threads are showing. And locknut should be up against lever.
1 - 2 of 2 Posts
