I just got a 1991 CBR250 MC22 into the US after a long drawn out import process. The bike has been dropped and has some worn plastics, but the seller was kind enough to include a used Tyga body kit. I haven't decided if I'm going to run it with the Tyga kit or use what's left of the stock plastics and make a streetfighter.
This bike's primary use will be at the track. Before I do take it there, I'm planning a restoration to get the bike in good working order. I'll need brake pads, brake lines (prefer braided), chain, sprockets, fuel petcock, all filters, spark plugs, and tires. I'm 180lbs so I expect I'll need heavier springs in the fork, and I'll want to replace the fork seals while I'm in there.
I'm guessing Honda used many of the same parts on different bikes, and I'm hoping wear items can be easily had from US retailers. Can anyone provide me with part numbers for the following:
Brake pads (EBC or other aftermarket brand is fine)
Fork Seals
Air Filter
Oil Filter
I'm 180 lbs (82kgs). Can anyone recommend a spring and fork oil weight I should start with?
Fork Seals
Air Filter
Oil Filter
