FS: wrecking mc22 QLD CHEAP!! (phots and prices now inc.)
hello i have acquired a mc22 and used what i needed and have the rest left over. i will list what i have used and almost everything that hasnt been listed will probably be available.
thats all i can think off for now.
pm me what you need with what you think is a fair price and ill shoot back
if you need photos ill try to arrange some for you. it turns out i am a complete noob when it comes to trying to link photos so i will only do it if needed.
Thanks
-=SCOOBER=-
more specifics on items that are available;
i have 3 spare cans: ALL $50 each
1. Omrae carbon can damaged but still good.
3. standard de-baffled exhaust with a polished stainless steel wrap around it.
Goodrich braided lines (front and rear)$110
Handle bars - $30 each
Master cylinder (front) $40 (rear) $20
Pillion seat $30
Riders seat $50
Carbs $180
Rear sets $80 for both
DISKS: $70 front $30 Rear.
Axle $20
Ignition barrel and tank lock(no boot lock avail): $50
H frame $40
Frame $150
Sub frame $50
Battery box $10
Undertray $50
Swing arm $75
Shock $40
Cluster bracket $30
Air box $40
Front calipers $75
Rear caliper $50
Coils $50 pair (including leads)
Forks (badly bent) $$lunch$$ pickup only
Petcock $30 (rebuilt 5 months ago)
Chain guard $10
i also have some headers i dont know what they are but compared to my stock one these look different. they have a crossover pipe between 1-2 and 3-4. never seen this before but these headers are in good condition.
on the front and rear brakes (master cylinders, lines and calipers) they have got near new pads, calipers look like they are in good condition and front and rear have Goodrich braided lines and no visible leaks.
I still have the carbies which have been jetted and tuned for use with a straight through can with out an air box restriction. but i do have the original jets.
i also have a fuel tap which has had a new diaphragm put in it in September 2013 and used for 5000 km's only problem with the tap is it can be hard to select "on". but has no leaks.
i am located on the sunshine coast and will arrange delivery at buyers expense. will also deliver as far as the gold coast alsong as the fuel used is paid for.
SO I HAVE USED / SOLD (NO LONGER AVAIL) :
ENGINE
FORKS
TRIPLE CLAMPS
TANK
FRONT WHEEL
SPEEDO STAY
STOCK EXHAUST
ENGINE
FORKS
TRIPLE CLAMPS
TANK
FRONT WHEEL
SPEEDO STAY
STOCK EXHAUST
Thanks
-=SCOOBER=-
Pillion seat $30
Riders seat $50
Carbs $180
Axle $20
H frame $40
Frame $150
Sub frame $50
Battery box $10
Undertray $50
Swing arm $75
Shock $40
Cluster bracket $30
Air box $40
Front calipers $75
Rear caliper $50
Chain guard $10
