http://www.youtube.com/watch?v=hiPb50D9G1wpsidey said:Hi to a fellow Canadian from a fellow Canadian, if we are talking about an MC22, the main bolt which holds the gas tank to the frame is an 8mmX35mm bolt Honda oem part # 95701 080 3500 which may or may not be available in Canada but should be available through a supplier, maybe Home Depot. The windscreen bolts are 6mm x 18mm long hex head bolts with a washer to go with it. If you are stuck you can private message me and I can help you out, psidey
