help mc19 headlight no power
1120 Views 3 Replies 4 Participants Last post by  Lane
88 mc19 left with a problem after a mate had wrong globes in headlights now no power to headlights all other electronics fine help .
1 - 4 of 4 Posts
Pull the headlight apart in case the higher wattage globes have burnt out the wires/connectors.
You may need to test each wire for continuity with a multimeter.
Check the fuses first, start with the easy stuff first then move on to the wiring.
Check your fuses and contacts however when you use higher wattage globes the higher current burns the L/H switch contacts.
1 - 4 of 4 Posts
