Finally got a bit of time to do a few little things to the bike today.
A while ago I purchased some braided front lines.
The brakes worked fine, more than enough stopping power for my riding (commuting mostly) but they were rubber and very old so I always had it in the back of my mind that they were well past their prime. And I reckon the fittings were a bit rusty and wouldn't last much longer.
And I always ensure brakes are as good as they possibly can be in all of my vehicles.
There were quite a few different brands around, ended up with these BTR ones from the UK via ebay.
New fittings were included which sealed the deal for me.
Fitting was simple, unbolt the old,
put the new ones in place, and bolt them up.
A good flush and bleed and they feel great. Definitely more solid now. I did a quick stop at 80 and thought I was going to flip it.
Secondly I've been monitoring the temp of the exhaust with an infrared thermometer, and cylinder 3 was a fair bit lower in temp than the others.
Thought I would swap the plug and see if that changes anything.
No change, but here is the old one.
It may did start a little easier.
I've also been having some small issues with the temperature.
When sitting in traffic it tends to rise up a little past half. Not sure what was causing it, the fan seems to be spinning ok.
Today I flushed the system, gave it a good clean and added new distilled water and coolant mix.
Idling in my driveway it seemed fine for a while, and then went a bit past half.
I gave it a slight rev, and the instrument lights seemed to glow a touch brighter, and maybe the fan was spinning quicker? Either way it dropped the temp a bit.
Seemed to be fine for about 20min, and then same thing happend. Rising above half at idle.
Revving it didn't seem to cool it down this time.
Water pump?
Thermostat?
Any ideas?
Water pump?
Thermostat?
Any ideas?
