Besides the bleeding obvious of the fuel line to pump, I've heard there is other vacuum lines etc from the tank?? Mc19 model? Could not having these lines setup cause running issues etc???
have you got the fuel pipes to petrol tank and to engineMC19 should have one line going to the fuel pump. If you're lucky there might be another one for the overflow drain attached, which isn't really necessary, it just shows that the bike hasn't been tampered with to some extent
do you hapen to have the fuel line from the tank to engineMC19 should have one line going to the fuel pump.
