Well something went wrong!!! I want to know what it was so it doesn't happen again after spending a ton of money fixing it.
Sent from my iPhone using Tapatalk
Well something went wrong!!! I want to know what it was so it doesn't happen again after spending a ton of money fixing it.Well if the orders were mixed up and the valves weren't put back into the right guides it's possible the one that failed was bigger than the guide it was put into and got stuck open from lack of lubrication.
Sent from my iPod Touch
Thanks for the help Clevermetal. Ill be giving the head and cylinders to a machinist to skim and make sure its square, hone the cylinders and give everything an acid bath. I'll be checking all the bearings and only replacing as necessary. From the look of CMSNL.com you cant get new wrist pins.I haven't had a look at these valves in a while but a lot of manufacturers friction weld the 'fat' bit of the valve onto the valve stem. Needless to say that they do sometimes fail... which might be what happened in your case. Just bad luck/poor maintenance/25 year old bike.
I doubt that it was an order mixup, for it to assemble perfectly enough to fit together/visually look fine but actually be parts from different bikes would be quite a feat. Especially by accident.
Pro-tip: to ensure your head is flat for when you reassemble it. Buy a really thick pane of glass (or stick two together) that you can stick 2 sheets of wet and dry down onto side by side. Then run the head over it until the entire bottom surface is evenly shiny. 100% flat and only costs around 20 or so bucks.
Well since Im spending a fair amount of money rebuilding the engine, I want do it properly and get the block proffessionally honed, skimmed and acid bath to clean the engine like newAmazing thread/work, can I ask how you would go about getting the engine block clean? I'm assuming dumping it in some diesel but are there any other specialist tricks?
Im about to load some photos of the plastiguage. It is a way of measuring the clearances between bearings. The tools I have in the box are bore micrometers. Accurate way of measuring the bore. I found the telescoping gauges and verniers to be just as accurate.Hey mate, awesome pics.. Whats plasticgauge and how does it work? Is that the box you have in the last couple pics?
