Project MC22 pedro
1576 Views 1 Reply 1 Participant Last post by  DMC
4
Got the MC22 bug back after a customer bought one to me for repairing.
It's been about 5 years since I've restored one, so I had to find one..
Got this from gumtree which seemed like a good deal.
It needs a fair bit if work as it's sat for 2 years..
Making steady progress and looking at early November completion..
I'll try and upload pics. Engine Auto part Automotive engine part Vehicle Machine
1 - 2 of 2 Posts
So far I've found rats have eaten through some wiring, thermostat was collapsed, carbies completely blocked, snapped Bolt on gear cover causing oil leak, 14 shim replacements and cam gear drive train noisy from worn shaft. Hence motor out as it's the only way to remove pin.
Also coolant over flow tank is cracked and very easy to change with engine out.
New fairings on the way.
It will get a full going over before blueslip Rego and then it's up from grabs once I out some klms on it..
  • Like
Reactions: 1
1 - 2 of 2 Posts
