RVF400 Rebuild
100394 Views 283 Replies 57 Participants Last post by  Lane
5
So,
Picked up this RVF today.
Uploaded with ImageShack.us
Yes, that is a VFR rear end, it's definitely a bitsa!
It has been sitting for quite a while, it wouldn't start so i drained the old fuel and cleaned fouled plugs and it fired up straight away! Motor has excellent compression, underneath all the neglect it seems like a pretty solid bike.
Bike is destined for a pretty comprehensive rebuild from the ground up.
Due to my new job i only really get one day every fortnight to work on it so progress will be slow but steady.
However now that i work for a bike shop, parts and accessories will be cheap.
After much deliberation i'm fairly sure it will be done in the Rothmans scheme although i'm still not 100% sure it could be a Repsol. I know they've been done to death but i just love them!
I'm also tossing up between which fairings to choose originally i was going to stick with the OEM design, but now i'm throwing the idea up of a Tyga RCV212 front minus the rear cause the RVF Tyga rear doesn't do it for me. There is an alternative rear that looks a bit like the '09 CBR1000's which i'm researching a bit more, so i'll keep you posted.
As far as mods go, i'll be fitting an Aprilia RS250 rear shock due to their adjustable rebound, compression, damping and adjustable ride height, with an 850 -900 pound spring to suit the RVF's shock lever.
Probably looking at doing the SP1 discs and calipers with master cylinder, also the rear needs a new disc and pads.
Going to upgrade the exhaust with a full system while i'm at it as well, probably go with a Tyga system at this stage as well as some better rearsets.
Anyway, stripped the buggery out of her today for a few hours and this is how she stands as of now.
So far bike needs a new left hand switch block due to a bit of road rash, also the top radiator has seen better days so will be replaced.
It has aftermarket triple clamps which i'm not really sold on cause they have no provision for the ignition barrel which was bolted to one side.
Anyone know what the deal is with bulkier "race" triples? They have "Trick Racing" etched into them, they look like they'd be heavier than factory so i don't understand the advantage?
Also needs the choke handle as the factory one was missing and was operated by what looked like a lawnmower choke handle mounted down near the idle adjuster.
Thats all i can really think of now but there will be plenty of updates.
Feel free to help with scheme ideas and examples cause i'm losing sleep over it!!!
281 - 284 of 284 Posts
I guess if you keep an eye on your oil like you should, there shouldn't be too many dramas
Can you please post up some pics of the damage out of curiosity?
I haven't pulled the bottom end apart so the pics would be pretty lame,
G'day!
Any progress on the engine work?
