I got myself some new. Ferodo brake pads went to put them on and found out I couldn't move the piston to make enough room, thinking I can outsmart this I put it in the vice to try and push the piston back in. After cleaning it up with degreaser. It moved a bit but not enough before rthe vice handle started bending. Its not a very big vice but I did have a pipe on the end of the handle for more leverage. I then took it off tried again but still needed more room, so back in the vice it went but this time I snapped the corner of the bench off. (Its a chip board bench but still pretty thick). Any ideas on unsticking my stuck piston or do I need a new calliper. Eagerly awating responses cause sooo keen for a ride
