Hey guys,
I've only ridden my MC22 about 3 times so I'm still a noob. It's always been about 15 degrees when starting it, and I've always had to hold the choke up when starting it. And I have to keep holding the choke up for atleast a minute or two before it will idle properly. If I only hold the choke up for 20 seconds or so, and then drop it, it will idle for a bit and then die..
Is this normal for an MC22? Should you always need to use the choke when first starting a bike? And should you always need to keep the choke on before it will idle properly?
Also, should the choke stay up by itself on the MC22? Mine drops down if I don't hold it up..
Cheers
Cheers
