Personally, I wouldn't go venturing into something like engine work which could be potentially very expensive with my limited experience. I would ask if I could watch someone else do it first, then find an engine I wasn't planning on using for a while to practice on before I would ever do anything to the engine in my bike.
As for removing it from your frame, you should probably stack something under it before unbolting it so it wont fall anywhere, unbolt it, remove the frame, move the engine to a place where it is not sitting directly on the floor. A stand or some pieces of wood under the sump and maybe gear box will both work I would say, use your initiative on that one.
This is all speculation as I have never removed an engine from a motorbike before, if anyone would like to tell me I'm wrong before nine goes ahead and starts work, go ahead.
