1 - 3 of 3 Posts
Hello lads,
I've recently bought a CBR250RR. I've come to realise that manoeuvring the bike can be a bit of a struggle at times due to the handlebars touching the tank as I try to do a u-turn or move the bike in a small space.
I've found that i am unable to do a uturn in a one lane area because of this. Is this normal for the MC22? Is there a way to adjust the handlebars and if not are there any aftermarket parts to change this?
Also on a separate note
- my front brake does not trigger the brake light, had a quick look at the wiring and all seemed okay. Any ideas?
Thanks Lads!
I do MSF drills on all of my bikes. mc22 is one of the most difficult. You can drop the forks in the triples a little bit to increase turn in, with the tradeoff of stability. I can make the small box when doing left turns, but right turns have my hand pinched between the tank and bars. Tried adjusting the clipon, but then it interfered with the fairing. I never went beyond that, since I rarely have a need to do a small radius turn. Still practice it, still struggle with it.
1 - 3 of 3 Posts
