Hi all
I managed to get the front sprocket to stop vibrating. Problem was that the rear wheel wasn't alinged properly. I went on the indicators and they where off. They indicated as alinged but they were out by 50mm on one side so I went off the pivet bolt and got it straight. Now the bike is almost running the way it should.
I'm getting a knocking sound and vibration from the clutch area (I think) and when I pull the clutch in the noise seems to go away. Or greatly reduce so I don't hear it over the exhaust. I dies it in neutral but gets louder and vibrates more as I ride. Clutch isn't slipping and all gears are changing fine, whether gearing up or down. I'm getting a knocking sound from the engine now as well and the exhaust doesn't sound right either. When I'm on the throttle is sounds fine but when I back off Its sounds Funny. Sounds like when your in high gear but low revs. Sounds like the exhaust is choking. Any suggestions? Maybe carbs??
Ohh and I've changed the oil and filter (did it today but made no difference). Used motul 10/40
