Hey guys,
My front tyre has a strip probably about 15cm long and 3cm wide where the white paint has been stripped off.. The wheel isn't cracked or anything so its not dangerous or anything.
There was a strip of white tape over it, which made it very very hard to see unless you look at it from 20cm away. I took the tape off to make sure there weren't any cracks underneath, and as a result the tape cracked, as it must have been there for a while and turned hard.
Don't have time for stripping, priming, sanding and re-painting the wheel so is there any other quick fix for this? (I may do this in uni holidays IF I have time and IF i can be bothered and IF it's not too expensive) Or should I just get some more white tape?
Also, the tape that was on there was very wide (wider than most white masking tapes that I could fine) and it was completely flat (as opposed to masking tape which has the small bubbles on it).. Does anyone know where I can get this tape?
Cheers
Cheers
