Just an FYI, I swapped everything over from an MC19 motor to the MC22 engine in the MC19 track bike.
All fits a treat & runs fine.
I just used a rattle gun to undo the bolt to get the rotor off.
if you still have trouble, pull the sump & put a piece of wood down ( or a steel bar if you don't care about the internals) to stop the crank from turning.
The bolt's on pretty tight, so you may need a decent breaker bar as well. Use a 6 point 14mm socket.
