Two50RR said:
some head lift stands give you multiple pins so you can use it with a range of bikes.....not sure of the kaneg ones though......
the kaneg stand which is the one i have comes with 5 smaller pins
there is also 5 larger pins as well which cost iirc $5 each
the RVF i assume would be the same as the VFR is one of the larger pins but i cant remember which , Kaneg will prob be able to tell you
but if you have the dollars just buy the extra 5 pins as you will prob use them one day anyway
alternatively if you google around and i would look at the greybike forum www.400greybike.cc and you will prob find out anyway
