MC22 Coil pack wiring and firing order
7.5K views 2 replies 3 participants last post by  motthomas
#1 ·
Hi Guys,
Can someone please tell me which colour wire should be going to each coil pack and then order of leads for each coil with cylinders going left to right sitting on the bike? Bike is a MC22 1992 import.
I've done heaps of searches and looked up the manual but seem to be getting mixed reports.
Cheers,
Brendan
#2 ·
Leads from left to right sitting on bike.
Coil 1. Coil 2
2. 3. 1. 4
The above numbers are cyclinders
Cyclinders are numbered 1-2-3-4 from left (side stand side) to right rear brake side.
The wiring from memory is black on right spade terminal and coloured on left.
Wiring is only long enough to fit correctly.
Close inspection you should see numbers on either end on coil ( black high tension leads) leads.
#3 ·
^^ what he said. Plus, the numbering on HT leads may not be correct if they were ever replaced or swapped around so don't take that as gospel.
As for wiring, the major yellow & minor blue wire plugs into the RH coil while the major blue & minor yellow wire plugs into the LH coil. As DMC said though, the loom is only long enough to fit where it needs so it should be pretty obvious if you get it wrong.
